If you look at the descriptions, the only difference between the four is the pipe diameter. You just need to pick the one that fits the plumbing you've got.
ugh, i just want to know what size I should order...I want to stick w/ Magnaflow since it matched my exhaust Also, I read somewhere that our Vibes have TWO cats? Does this mean I have to buy two??
Easier said than done when, a) I don't have jack stands, b) nor ramps, c) nor a floor jack, d) very little free time.This is why I come to you guys for advice.
Quote, originally posted by Psychobroker »Easier said than done when, a) I don't have jack stands, b) nor ramps, c) nor a floor jack, d) very little free time.This is why I come to you guys for advice.Free advice is often worth just what you pay for it, Psycho! A few points:o Saved and Dimtri are wrong! (sorry guys) On the base engine there are definitely TWO cats! (and I'm 95% sure it's ditto on the GT) One is right at the exit of the header and the other is a short distance downstream, followed by a resonator and finally the muffler. Take your Vibe to a friendly garage for an oil change and get them to let you take a brief walk under the hoist and check for yourself. o That said, it would be quite hard to change the first cat, as it is practically a part of the header. o Also, in many jurisidictions it is illegal to change out a functioning cat.o Lastly, before removing the factory part, you should seek some unbiased assurances that the replacement will actually flow better!
I asked ptuning for more information about the model they list. Here is what they say:[ Dear Customer,Thank you for your inquiry.You can gain some hp with a high flow cat. Keep in mind that the cat isuniversal fit, so that muffler shop will have to weld the cat to yourexisting system.Please contact us if you have any further questions.Sincerely,Performance Tuninghttp://www.ptuning.com"Low Price Guarantee"
