Quote, originally posted by drw2514 »i want a HU that I can use my iPod with, so an aux input is a must. Other than that, it's pretty much up in the air.i'd really like to not go over $329 for the HU (that was the most expensive one I was looking at...).I personally try to reccomend the Pioneers. Why? They sound nearly as good as the Alpines, and they're quite a bit cheaper. The 9807 is nice, but a lower-end unit. I'd reccomend the Pioneer DEHP-6600.
http://www.circuitcity.com/det...87377For only $250, you get a great display, a great AM/FM tuner, and a pretty hefty set of crossovers and audio options built in. For the aux in, add this -
http://www.crutchfield.com/S-J...avf=NThe CC page says "Aux In - NO", but you can add that adapter from crutchfield and it'll give you an aux in. Either that, or step up to the Sony CDXM800.
http://www.circuitcity.com/det...68777I know I said avoid Sony, but this unit is still as quality as the original ActiveBlack units (like one I used to have). This has the Aux In built in on the back, and still gives you all the sound fixin' abilities.Quote »What do you think of the speakers? Are the polks good? I'd probably get the 6 1/2" ones with what I've learned here...do the 6 1/2" speakers require any modification to the vehicle, or do they fit in the opening that is already in the door? just curious.They aren't bad. I try to reccomend Polks as often as possible, because I love how they sound. If you can't afford the component sets.. ($199 at CC), then stick with what you found. I'd even say get one of the component db series in the front, and stick with what you have in the back.. it raises the price about $100, but I find it to be well worth it. (Personal opinion, of course..)For the rear speakers, it just sits in the hole the old speakers went in. For the front, I think you have two options, you either need to add a spacer (so the magnet doesn't hit the window), or tear out the guts of the front speakers, and mount the new ones in the cone of the old ones. CC might not do this, as we're supposed to be able to return your car to stock, so you can either tell them to do it, or get the spacers, which they should have..Quote »I'm looking to get all of this done this week, and all of your help is invaluable. I'd be lost without you, as I know next to nothing about all this and I don't feel completely comfortable trusting someone at a store. Thank you so much.Oddly enough, you're trusting someone on a computer, who happens to work at one of those stores! But, I only work there because the job market for television is kinda thin down here.. If you want the option that'll work for you straight away, try the Sony CDXM800, or even the newer CDXF7700 (
http://www.circuitcity.com/detail.jsp?c ... &oid=87279). Both have aux in without an extra adapter, nice screens, and pretty good sound. A nice benefit of the 800 over the 7700 is the motorized flip face...you dont' need to remove the faceplate, because it's completely black when closed..Hope it all helps!
