Well, with that dash after the 5, it should mean machined for 5 wheel studs and with a double or slotted pattern fitting both a 5" and a 4-1/2" bolt circle diameter. (The Vibe is 100 mm, or 3.94") It might however just be a doubling up on the 5 bolt pattern info and indicate a 4-1/2" bolt circle
