interior door
jaceygong
interior door
Post by jaceygong »
i want to upgrade the door speakers and can not remove the door panels without a special tool for removal of the handal...can someone tell me the tools name so i can buy it or a method that doesnt involve this tool.base model 5 speed with manual windows not power. thanks
ragingfish
Re: interior door (jaceygong)
Post by ragingfish »
The door panel comes off without removing the handle.Unscrew the screw in the little cup/handle thingy that you pull on to close the door. Behind the door lever, there's a little flap. Stick a mini screwdriver and pop that. Then unscrew that. Then just yank, it'll come right off. No special tools needed.
2009 PONTIAC G8
jaceygong
Post by jaceygong »
thanks man i will give it a go.... if i do it right i will have saved 100 on installation for the speakers...thanks again
Kangaroooski
Re: (jaceygong)
Post by Kangaroooski »
There is a clip on the underside of the window crank, if you dont take this clip off you will break your crank (I know from experience).
Kangaroooski 2003 Neptune Vibe (base) 5-speed 16" alloy wheels Thule playpen basket Hidden Hitch DeBadged 2004 cladding installed LETS GO RED WINGS 2004 Yamaha FZ6 with satellite navagation
scherry2
Re: (Kangaroooski)
Post by scherry2 »
Quote, originally posted by Kangaroooski »There is a clip on the underside of the window crank, if you dont take this clip off you will break your crank (I know from experience). use a pocket screwdriver. the clip is u shaped
Jahntassa
Post by Jahntassa »
It's literally called a window-crank removal tool. You need to be careful with that clip, they're farily easy to break (and lose)It's evening..so i'm braindead..heh. But if you want a description on how to remove it (if you didn't figure it out by then), let me know.
mwebb
Re: (Jahntassa)
Post by mwebb »
They sell the tool at murrays for like $5
18in Kaizer PHX II wheels / Toyo Tires / Tint2 way pager system alarm/remote starter2 Eclipse 12's / Eclipse HURemoved cross bars / Custom SBReflective red badge overlays / Red Vent Covers Pics Soon Billet Grill /LED underbodysFront tint / Windshield vinyl My Vibe - http://www.cardomain.com/id/webbsvibe
