GTP motor in Vibe?????
dcyco1
Post by dcyco1 »
Has anyone ever thought of transplanting GTP motor in the Vibe. They already do this to Cavaliers so I am wondering if this could be done. I know it would be tight but if it fits, it could be made to work. I would think this would be a cheaper option in the long run compared to a turbo setup.Just wondering......
2004 Shadow Vibe2000 GTP1996 WS6 TA
ALi3N
Re: GTP motor in Vibe????? (dcyco1)
Post by ALi3N »
If you are refferring to the Grand Prix GTP, no. The GTP uses a Supercharged 3800 SFI V6 that takes up a lot of real estate under the hood. The Vibe barely has enough room for a supercharged 1ZZHE 1.8 L4 that is offered. I am sure with enough cutting and welding and tens of thousands of dollars, perhaps... but not worth the trouble IMO.
ALi3N aka Dj ViP3RThere is a force through the euphoric beat causing uncontrolablemovement of your body, I am that force. Take a journey beyond the limits of your mind.'Download Mixes:http://shlrm.org/DjViP3R/http://www.myspace.com/djvip3r Latest Mixes: 'Nightlife' & 'M0Ti0N -X-'Pimpin' Abyss Vibe GT w/ Nav
bassvibes84
Re: GTP motor in Vibe????? (ALi3N)
Post by bassvibes84 »
Well,I dunno. If you compare the two side by side, it could probably be done with a little fabrication. And a lot of computer work. However, the power gains may or may not outweigh the added weight of the bigger engine.
Stang2Vibe
Re: GTP motor in Vibe????? (bassvibes84)
Post by Stang2Vibe »
And the way that the weight is located will make the Vibe handle very different I would think. It would require suspension work as well, and still may never be quite right (without getting into major bucks anyway).
