Oil pump.
engine1
Oil pump.
Post by engine1 »
Does anyone truly know where the oil pump is driven on this motor! Is it off the crank, gear driven, shaft driven?
Abyss Monotone Power Package All exterior lights upgraded to Piaa 60 Series Flowmaster, K&N Typhoon Autometer liquid filled oil pressure guage 5% Tint on all five rear windows Hurst Pistol Grip shifter, Piaa Sports Horns
NovaResource2
Re: Oil pump. (engine1)
Post by NovaResource2 »
The oil pump bolts to the front (passengers side) of the engine and is driven via flatspots on the ends of the crankshaft. The crank pulley slides on the ends of the crank and inside the pump.
engine1
Re: Oil pump. (NovaResource2)
Post by engine1 »
So just a straight gear to gear drive then?
NovaResource2
The oil pump is a sun and ring gear. The sun gear is driven by the crank, the ring gear is driven by the sun gear. Similar to the pics below (the pics below are not of the actual Vibe pump):
