Sub in spare tire?
mrsamwong
Sub in spare tire?
Post by mrsamwong »
Has any tried to install a sub inside the spare tire? Just wondering if it's possible.
wicked1981
Re: Sub in spare tire? (mrsamwong)
Post by wicked1981 »
Quote, originally posted by mrsamwong »Has any tried to install a sub inside the spare tire? Just wondering if it's possible.It is possible all you need is money and a good shop that will fabricate something.
2006 Pontiac G6 GTP3.9L V-6 240hp and 241 lb-ft or torque18" Aluminum, five-spoke, flangeless200 Watt, 8 speaker Monsoon sysChrome dual exhaust tipsLiquid Silver MetallicBorla Custom ExhaustDr. Speed Cold Air Intake
Fialchar
Re: Sub in spare tire? (wicked1981)
Post by Fialchar »
You'd be able to but you'd need to make sure that the sub has enough room to breathe, that it won't vibrate against anything, and as a safety precaution, make a removable box for it so you can still access your spare tire. What would look nice is to take out the removable grey flooring of the hatch and have a sub enclosure custom made to fit inside of it so it will look flush with the flooring when you put it back on. A shade of light to dark grey carpeting over the plastic would also look nice. If you have any questions on suggested brands of wiring, power capacitors, amps, subs, etc, feel free to ask.(I thought of doing something with tires, but it was for a home theatre system. I thought of having the sub for a surround sound home theatre set inside of a low profile tire, maybe fitting an 18" RF sub inside one of my 215/35/18 once I replace them
