I want to add some hp and torque to my base vibe. I was thinking of getting an Injen CAI (Q: #1: which one do i want?) but I was reading on the bottom of the info page and it says something like having to REMOVE the filter in wet conditions because it is possible for water to get in your engine. (Q: #2: ummm, do people reall remove them?? I mean on an everyday driving car?) OK, about the chip... my uncle was saying something about changing the computer chip in some vehicles will also increase hp and torque. Has anyone heard about this? Has anyone tried it? Cost on something like that? I'm looking to spend just $500 on upgrades for now. What is recommended?? Thanks!
'03 Base VibeSatellite MonotoneMoons and tunesKeyless entry / electric everythingTinted windows and pin stripe (ordered from someone else)Metallic white overlays, Pearl white rims paintedNext: Magnaflow exhaust & Injen CAI Xenon blue head-light bulbs and blinkers
First off, Hi! Second, I have the Injen and have driven nearly 4000 miles in Montana winter on the highways. I've not removed my intake and have had absolutely no trouble at all with mine. It barely even gets wet. The one time you'd have to worry about it is if you live in an area that is prone to floods when it rains. You have to completely submerge the filter in water to have a problem. That translates to 6+ inches of water. If this would be a concern, you just have to switch back to the stock intake during the wet season. It's a lot of work to do, but it can be done. The alternative would be to go with a short-ram style intake.As for the chip, I'll let someone else answer that. One of our members, TRDVibe has one installed. She'll have some good info for you there.
millster is right.. you only need to worry when the whole pipe is submerged in water... go 4 it.. get AEM intake:)
My Car, with the kit on. it looks awesome! come and check it out, tell me what u think.P.S. the gray will be painted momentarily http://www.cardomain.com/ride/514882/1
now i saw on a forum on here that Injen was the best??
Quote, originally posted by vibechick03 »which model of CAI do you have?? I have the Injen intake from ptuning.com. Here's the link to it for the Base Vibe. Click Here
umm, can i get that in blue instead of red?? i know thats not a big deal to some, but gotta stick to my colors!
they are both good....u cant go wrong.. unless u get TRD!!!
you can also install a bypass valve, which will prevent the filter from drawing in water if you want to run year round with the full CAI.
Abyss Monotone Power Package All exterior lights upgraded to Piaa 60 Series Flowmaster, K&N Typhoon Autometer liquid filled oil pressure guage 5% Tint on all five rear windows Hurst Pistol Grip shifter, Piaa Sports Horns
but then u have to cut the CAI in half... AEM HAS BLUE INTAKES!!!GO AEM!!!
i have a GT w/ TRD CAI and a Unichip. My color scheme however is red, and so i love the TRD candy apple red! between the 2 engine mods, i really don't know what hp or torque increase i have. i can def feel a big difference when i put my foot on the gas. really you're best bet if you want torque and hp is the s/c for the base. plus, if you only want to spend like $500, then you should go w/ a CAI/exhaust combo from pttuning or something.... just my thots tho.
I believe that the flowmaster exhaust gives you a 8hp increase. Not sure about increase from the intake. I read it was 12hp increase on a GT not sure about a base. So you should go witht eh combo from Ptuning.com.
