Stock radio removal?
ebslopp
Post by ebslopp »
I'm sure this has already been posted, but I couldn't find it. Can somebody please tell me how to get the stock radio out? If you have pics of the process, that would be helpful.
--------------------------------------------------------------------------------2004 Base - TwoTone Neptune - 5 speed There are 10 types of people in life. There are those who understand binary and those who do not.
Sub-Vibe-R
Re: Stock radio removal? (ebslopp)
Post by Sub-Vibe-R »
1- remove the grey platci around the HU.To do it, pull the bottom of it, the pull the top.2- Unclip the wiring harness (3) and the recycle cable.Be carefull with this one, you can brake the pins easily.3- Remove the 4 10mm bolts and the HU is yours.
cohocarl
Post by cohocarl »
I posted a couple shots on how to remove the bezel w/o breaking the clips that may help you on this post: (scroll down a bit)http://forums.genvibe.com/zerothread?id=769The pic here shows the 4 bolts that need to be removed. A 1/4" drive with a long extension helps for the two lower bolts. I "pointed" to the bolts in red in this pic.
Sold 6/16/04 03 Vibe 5-speed, Hotchkis Sway Bars & Springs, Hooker Aerochamber, Panasonic Stereo, Hitch, Silverstars,04 Saturn Vue 2.2L Ecotec, 5-speed, 01 Stratus R/T Coupe 5-speed (wife's car) 85 Corvette 268 CompCam, 882 heads, FlatTops, 24lb injectors, Hooker Aerochamber true duals, 58mm TB, Holley AFPR, Siamesed intake base, Polished TPI.
