New battery
DonB
New battery
Post by DonB »
I'm glad I got the new upgrade battery put in a week ago today, we had fifteen below this morning and as stiff as the car was I don't think it would have started with the old battery.
engine1
Re: New battery (DonB)
Post by engine1 »
I just changed my battery after a very cold morning for this area just about killed the stock power plant! I checked the size and found that an AC Delco 85-7YR fits perfectly if you use the adaptar under it and provides 850 CA.............WOOOOHOOOO! Called my rep and got one n/c! Now it should crank at -40!
Abyss Monotone Power Package All exterior lights upgraded to Piaa 60 Series Flowmaster, K&N Typhoon Autometer liquid filled oil pressure guage 5% Tint on all five rear windows Hurst Pistol Grip shifter, Piaa Sports Horns
Raven
Re: New battery (engine1)
Post by Raven »
Quote, originally posted by engine1 » I just changed my battery after a very cold morning for this area just about killed the stock power plant! I checked the size and found that an AC Delco 85-7YR fits perfectly if you use the adaptar under it and provides 850 CA.............WOOOOHOOOO! Called my rep and got one n/c! Now it should crank at -40!How did you swing that deal? Please let us know ASAP. My dealer said the free replacement is only available in the USA.
engine1
Re: New battery (Sunny)
Post by engine1 »
I sell auto-parts for a living. One of those lines is AC Delco, I just called in a favor, and got one written off! But the point was that there is a very stong battery available that at the very least the dealer could pro-rate the battery in your vehicle and give you the value against one with higher CCA.
ragingfish
Post by ragingfish »
What does that battery run MSRP-wise?
2009 PONTIAC G8
engine1
Re: New battery (ragingfish)
Post by engine1 »
About 80 bucks(CAN) across the counter!
