Is there anyway to somehow tighten the interior door panels to make them stop vibrating? And my plastic gauage cluster thing vibrates now too and its on as tight as it can be, is there a way to stop that too? These not-so-high-quality plastic parts are killing me...thanks
What makes them vibrate? If it has anything to do with the speakers/bass. then look into this for door panels. I seen this at Best Buy and they install. Dont know about the gauges though.http://www.dynamat.com/
yeah, pull the door panels off, and remove the white clips. now wrap the top (part that goes on the door panel, NOT the door itself), with dum-dum, ribbion tape, felt strips.....reinstall on panel, now install panel on door if done right you WILL NOT have any more rattles...unless you've blown the speakers
03 toyota matrix XRS 6 speed, lunar mist,factory 17 inch rims w/firehawks- summer tiresfactory 16 inch rims with dunlops- winter tirestrd sway bars, trd strut brace, trd sport muffler,trd quick shifter,trd cold air intake, toyota tundra dual horns,factory toyota wing from toyota canada, both front door handle modsNEW pioneer AVIC-D1 nav unit, XM radio installed
