Rear stock speaker sound
Craigmri
Post by Craigmri »
I have the 200 Watt amp with 6 disc in-dash changer. I experimented with the stock speakers today by adjusting the fade control to direct all sound to rear speakers and then only to the front speakers.......the rear ones sound like crap! Has anyone else noticed this?
Craig
Vibe
Re: Rear stock speaker sound (Craigmri)
Post by Vibe »
Yes I did and noticed the same thing. My right rear speaker sounds raspy and I think I might of damaged it with my loud volume that I listen to . So yes better speakers or on the horizon. Vibe
Jahntassa
Re: Rear stock speaker sound (Vibe)
Post by Jahntassa »
The rear speakers in the vibe are only 5", but when you pull out the whole plastic bit that holds the speakers, you can fit 6.5" (6.5" oversized might work better). ANYTHING is better than the stock speakers, even for the Moon and Tunes. Mind you, if you like them, then great! Heh..but..they're still paper..and they'll still disintegrate. I have a pair of pioneers I pulled out of my back doors that I can probably send to someone.. $25 over paypal and they're yours!
tbm34
Post by tbm34 »
Quote, originally posted by Vibe »Yes I did and noticed the same thing. My right rear speaker sounds raspy and I think I might of damaged it with my loud volume that I listen to . So yes better speakers or on the horizon. VibeDo you think the front stock speakers are any better, or just not as crappy?
Base Shadow monotone 5-spd, Moons & Tunes, Power Package & ABS. Alloy wheels, Progress RSB, Silverstars. TRD supercharger w/ custom tuned Unichip, and magnaflow true cat-back exhaust.
Psychobroker
Re: Rear stock speaker sound (tbm34)
Post by Psychobroker »
Not so much better, but larger. They're still crappy.
