abs contrtoller
russ257
abs contrtoller
Post by russ257 »
ok you all know i had an accident and the car is all fixed up we now are just waiting on an abs controller. they are apparently on backorder and earliest availability is feb 23 which is unaccaptable because they have had my car since nov 27. My question is does anyone know if the abs controller out of a matrix is the same part. and how would i go about getting in touch with pontiac to complain to them and try to get on pulled off of the factory line?
'03 VIBE AWDPioneer AVIC-N1MOMO 6.5" componets in frontMOMO 6.5" speakers in rearJL e6450 six channel ampJL 12" w3 subAlpine 120W amp powering the sub
ragingfish
Re: abs contrtoller (russ257)
Post by ragingfish »
I'd think it's a safe bet the ABS systems are identical...my ABS thing says either denso or toyo on it, so...even without an abs ocntroller you can still drive the vibe...but i know you want it back to the way it was...
2009 PONTIAC G8
russ257
Re: abs contrtoller (ragingfish)
Post by russ257 »
the guy called the top guy in philly and they found one and my car should be done tomorrow
