Vibe Part # 8070.01 Height adjustment 1.5 to 2.8 Price $419 Matrix Part # 8070.01Everything is the same as the Vibe. This system allows you the option to customize the ride height of your vehicle. Unlike other spring kits that require removal of the strut assembly, the unique design of the Ground Control kit allows for quick, easy adjustment. Simply lift the corner(s) to be adjusted and spin the adjuster up or down to raise or lower the vehicle. Ground Control spring kits are designed to be used with either stock or aftermarket shocks. Springs: All our ride height adjustable kits feature Eibach Springs. these high quality springs offer a lifetime warranty against any defects. Adjusters: All adjusters consist of a threaded sleeve and adjustable spring seat and are made using 6061 aluminum, anodized for greater durability and appearance. All other adapter hardware is machined from the same high strength 6061 T-6 aluminum. Ground Control
Replace your shocks and the problem (if you even have this problem) would be fixed. I personally would love this set up since you have total control of how low your vehicle will be. Plus you can't even come close to beating the price.
