I'm not familiar with QuickTrip... I am guessing it is a station? We have only 1 station in my area that has an ethanol blend ...
Mohawk.It's not the alcohol that gums up stuff, but the additives they need to put into ethanol-blended fuels. I'm no chemist, so I can't tell you which ones they are, just what GM has told me.According to the 2003 owner's manual (which you can access in this thread
http://forums.genvibe.com/zerothread?id=1010), page 6-5:Quote, originally posted by GM »Your vehicle was not designed for fuel that contains methanol. Don’t use fuel containing methanol. It can corrode metal parts in your fuel system and also damage plastic and rubber parts. That damage wouldn’t be covered under your warranty.Notice that it says METHANOL. Methanol & ethanol are 2 different things (according to the fuel companies). GM says that ethanol is OK in the manual, but the person on the 1-800 line said it's not. I don't know. I have a feeling that no one really knows. Either way, I'm just going to steer clear of it.
2003 Satellite AWD Two Tone, traded off at 180,126 kmNow the (fourth) catalytic converter is someone else's problem Now driving a 2007 Dodge Grand Caravan
