Nope -- I've had it at the top of my windshield after it was replaced, but never in the doors.I have noticed that - now that it's cold - I can hear road noise more from around the doors..... makes me wonder about the seals.....
2003 Shadow Vibe -- Alloys, Auto, and Allota fun!Vibe #4,873Sadly, traded-in for a 2005 Dodge Grand Caravan
I had a water leak at the top of my front passenger door the first week I had my Vibe - water rolling down the A-pillar in a heavy rainstorm.When the tech lifted the seal off, a bunch of water poured out, so no need to try and prove the leak! They fixed it for me with no problem - same day I took it in.
Used to have: 04 Monotone Abyss 5 SpeedNow the proud owner of a black 2005 SRT-4230 Hp250 lb/ft torque
Well the dealer found out that BOTH rear window seals are leaking and bad. I told them that much. So they are going to replace them next week when they get the parts in. So I guess it's towels on the back seat until then.
Quote, originally posted by adventurer » Well the dealer found out that BOTH rear window seals are leaking and bad. I told them that much. So they are going to replace them next week when they get the parts in. So I guess it's towels on the back seat until then.you might want to have the tech fit the doors a couple of millimeters closer to the door frame. I watertest GM trucks and that is what I see when the doors leak. the door is not making solid contact with the door frame weatherstrip and water leaks by. just a suggestion
