Security System light does not come on
Dunkie22
Post by Dunkie22 »
HELP! My security system light no longer comes on. I close all the doors and I make sure the back hatch is closed firmly. I opened and closed the moon roof (although it has nothing to do with it). I looked through the forum for similar problems. Now with that being said, I had my speakers replaced. That requires taking off the door panels. I took the car back to the people and had them check. When looking at the car, it appears that the microswitchest are on the main body and not the door;so, the speaker change should not have anything to do with it. Anyone had a similar experience or can offer a suggestion?Thanks!..love my Vibe and this forum is greatDuncan
Base, Fusion Orange, Moon & Tunes, Power, Protection, auto, ABS, 16" allum wheels, Eclipse stereo, diamond speakers in front and kenwood Excellon speakers in the back
Jahntassa
Re: Security System light does not come on (Dunkie22)
Post by Jahntassa »
Does the alarm still go off? And do you use the keyless entry to arm it? It does have to do with the switches in the doors, but unless they rewired something wrong..it shouldn't affect it. Try this... open a window..close the doors and lock them with the keyless. Wait about 40 seconds..then unlock the door by reaching through the window, and open it. If the system goes off, the light is just messed up. If the alarm doesn't go off, they definitely did something when they installed the speakers.
Dunkie22
Post by Dunkie22 »
I actually tried your idea. Nothing happened. The doors stay locked, but there is no alarm at all. thanks for your suggestion.Duncan
ragingfish
Post by ragingfish »
Well, if your system won't function anymore, my advice: take it to the dealer, get a diagnosis and a price estimate for the repair, and walk back to the stereo place.Hand them the estimate, say "it worked before you touched my car," and walk out with a check for the repair amount.
2009 PONTIAC G8
Mavrik
Re: Security System light does not come on (ragingfish)
Post by Mavrik »
The security system might need to be reprogrammed if its not arming when you lock the doors... It should be set off when you lock the doors with the remote but open the door with the key.But are you refering to the flashing light on the radio?
Dunkie22
Re: Security System light does not come on (Mavrik)
Post by Dunkie22 »
No..I am referring to the light on the dash right next to the driver's door.
