I just put a 40 series muffler on my GT. It sounds pretty good but I think it coukd be better. I left the stock resonator on thinking it might keep the db level down, it does. I think I might remove it and see if that makes it a little bit more aggressive sounding.
03 Abyss Vibe GT 72 VW Beetle stdThe object of war is not to die for your country but to make the other b*****d die for hisGeorge S. Patton
The 40 Series is designed for big block V8 powered cars. I'm curious as to why you chose this muffler instead of the 60 Series which is designed to bring the Flowmaster sound quality to 4 cylinder engine cars.
The guy who did th work only had that type. I still might put 60 series on the car. I will buy those from ebay if possible. it doesnt sound to bad but I believe it could br better.
Did you have this done at a local shop and is that price including reattaching your resonator? How does the sound with the new muffler compare with and without the resonator? I was going to have the res cut out, but now I might keep it. I don't want to wake up all the neighbors at 5am.
I paid $140.40 with tax. Not to bad, another place in town would have put me near $200. I think I am going to replace the 40 with 60. The 40 has a hollow sound to it with a slight rasp.
wait how loud is loud?? like it is annoying or jsut during acceleration?i used to use my resonator as my muffler when i had straight pipe in for the muffler. Is it louder then using just the resonator is basically what i am asking.
and how does the resonator change the exhaust note? (Not mechanically, but in sound terms)
actually, I watched the guy cut the old one off, and just weld the new one on, even used the tip from the stock one. I'll take pictures tommorow from under the car..
Quote, originally posted by Stang2Vibe »The 40 Series is designed for big block V8 powered cars...Hey Stang, Have a look at one of the 50 Series Flowmasters for my Big Block (aluminum 495 c.i.) Camaro!
Wow! Those inlets/outlets are HUGE! Looks like something we'd have on our Mack trucks at work! I know the 50 series is designed for the big blocks as well. One of the two is supposed to be just ridiculouly loud, though.BTW--I thought that the GT's exhaust was 2 1/4?
How much would a custom job run me? Is there a brand I should stick to? Dont know much about exhausts but I want something that dosent sound like a pissed off weed eater I just want it to have a deep roar but not a loud one to be quiet until you step on the gas. Damn I sound lost!!!
2006 Pontiac G6 GTP3.9L V-6 240hp and 241 lb-ft or torque18" Aluminum, five-spoke, flangeless200 Watt, 8 speaker Monsoon sysChrome dual exhaust tipsLiquid Silver MetallicBorla Custom ExhaustDr. Speed Cold Air Intake
There are a number of tips and mufflers that have twin pipes close together, but you could use something like a Flowmaster for a Camaro, with a single inlet and dual outlets to get true left/right duals. I built my own by tapping in upstream of the stock muffler, per following pic. Most of the sound comes out the right side, but it is a dual set up!
Quote, originally posted by Stang2Vibe »Wow! Those inlets/outlets are HUGE! Looks like something we'd have on our Mack trucks at work! I know the 50 series is designed for the big blocks as well. One of the two is supposed to be just ridiculouly loud, though.Well, they are pretty well empty cans, and they aren't the newer "Delta Flow" design, so with 1 litre per cylinder and 13.5:1 compression ratio, I don't expect I'll be sneaking up on anyone...
Good Lord, MadBill! A deaf man in Sri Lanka would hear you pulling up your driveway!
ROFL!Even when I had the small block with 'only' 3" exhausts (and 11.8:1 CR), there was a bit of a sound "issue". My buddy's Mom said she always knew when I was coming, because her kitchen windows would start rattling when I was still two blocks away....
Quote, originally posted by MadBill »There are a number of tips and mufflers that have twin pipes close together, but you could use something like a Flowmaster for a Camaro, with a single inlet and dual outlets to get true left/right duals. I built my own by tapping in upstream of the stock muffler, per following pic. Most of the sound comes out the right side, but it is a dual set up!Doesn't that make for one tip that is louder than the other?--Matt
Quote from MadBill,Most of the sound comes out of the right, but it is a dual set up!Doesn't that make for one tip that is louder than the other?--Matt[/QUOTE] Most of the sound would tend to mean louder!
Quote, originally posted by Sunny »Quote from MadBill,Most of the sound comes out of the right, but it is a dual set up!Doesn't that make for one tip that is louder than the other?--Matt Most of the sound would tend to mean louder! [/QUOTE]Ya, I noticed that right after I posted.--Matt
Unless you're standing right at the bumper, it's hard to tell that one pipe is louder. Also, in cold weather there's still enough flow through the muffler that clouds of condensation come from both.
