Polk db component speakers?
Spatula
Post by Spatula »
Polk is currently having a sale on speakers (buy one pair, get one 50% off). I'd like to buy two pairs of these, one pair in front and one in back. I know the front speakers need to be shallow or they block the window glass. Does anyone know (from experience or otherwise) if these will fit in the front? Thanks.-Spatula
Jahntassa
Post by Jahntassa »
I actually put the Polk/MOMOs in my front, without cutting into the door panel. So these should fit..In the rear you shouldn't have a problem at all. For the front, you need to mount them on top of the existing speaker.I have the MOMOs in front, which, i'm pretty sure, are deeper than the db series.
Spatula
Post by Spatula »
you are correct, the MOMOs have a larger magnet and are deeper, so these should also fit. thanks again!
TopGunn23
Re: Polk db component speakers? (Spatula)
Post by TopGunn23 »
Yea i have heard these are good speakers for the vibethere should be no problem with them fitting in the doors. Enjoy and hope it works out great for u. Nick
