Quote, originally posted by davidelewis »[1] Although wonderfully fuel efficient, the Vibe is truly gutless. At highway speeds it does quite nicely, but in circumstances that require torque (such as uphill starts, etc.) it performs poorly. Although the engine noise may be lower (less decibels) or equivalent to the Aerio at most speeds, the pitch is often higher - the Vibe is more whiny!The engine is somewhat loud, but certainly not that bad IMHO.As to gutless, I disagree by far! What model did you test drive? If it was AWD, keep in mind those have the lowest horsepower of the three models. Also, if you get a stick, it's much more fun, and you gain more control over things such as uphill starts.Quote »[2] The "tippiness" is almost as bad as the Aerio. We were disappointed when test driving the Aerio on a tight windy road. The Vibe didn't fair much better - it was about 85% as "tippy" as the Aerio. I'm guessing because they both have a tall body that this contributes to the effect.Correct. The center of gravity is higher in these cars, making them more prone to the tip-like effect. However, I definitely find the car handles amazingly, even on tight turns.I'm going to be lowering mine about 2" in the near future. That also improves handling. Things such as a sway bar or stickier tires also would help.Quote »[3] Although the seats in the Vibe are plush and initially comfortable, I found that I could never position the seat quite correctly so that I was comfortably positioned with my arms and legs. Either my legs were comfortable but I had to stretch with my arms for the steering wheel, or the arms were great but my legs rather jammed. I find this surprising as although 6' 1", my legs are a little short and my arms are a little longer than usual.Can't help you there. I'm 5'5" and have no problems getting a comfortable position.Quote »[4] Although the plastic trunk seems initially appealing, I have no doubt that cargo would slide around all over the place. Although the Vibe provides a funky set of loops that slide along tracks for securing a load, they look like they are more hassle than they are worth. This is a problem that shows up in virtually all reviews that I've read - ranging from the favourable to less favourable.Yeah, stuff will slip. Get the GM cargo mat, or go to lowes or home depot, buy some matting fora botu $10, and cut to fit. Many members did that. Helped a lot.As to reviews, well, these people are stating their opinon. Just because they say somethign is good or bad, it doesn't mean it is. It's all opinionated. Quote »[5] A posting in the GenVibe forum cave me reason for concern. It outline the various problems that Vibe owners have had with the 2003 model: battery, daytime running lamps (DRL), cladding replacement (2003>2004), mudflaps, discoloured cladding "weatherstripping", paint chipping, clutch wear/ smell, a/c noise. These issues were an accumulation of problems that Vibe owners had that the GenVibe administrator talked with the Vibe Quality Manager at GM. See:
http://forums.genvibe.com/zerothread?id=6124One thing you need to keep in mind here is that the Vibe has only been in production for a little over a year.Most new car model launches are plauged with quality issues. It's to be expected. Remeber the launch of the Focus? It was a disaster. But after a year or so, most of the major things are worked out.Same here. Yes, there's an issue where the cladding on two tone models can get "sandblasted." That's not he fault of GM. It's due to rocks. They realized it was aproblem, and issued a service bulletin that will replace damaged clading and give you extended rockers to guard against futre damage.The weak battery is being adressed. We've been told a TSB is due out before xmas authorizing an upgraded battery in situations that call for one.The paint is an issue with many cars these days. I've had people who own fords, mazdas, vws, and dodge's all raise similar paint concerns. The guys at GM are taking our concerns to heart and looking to be sure there isn't somethin in the process causing the problem.A/C noise is new to me. Don' remember hearing anything there.AFAIK, the discoloured weather stripping only affected a handful of people.Anyway, you had the car for 24 hours, so you know how it will handle. I think you'll be very happy with it...there's about 1000 or so people here who love them...but you kinda need to decide if it's the right mtch for you.
2009 PONTIAC G8
