Cold Idle Speed...
sevenofnine
Cold Idle Speed...
Post by sevenofnine »
Seems rather high to me...2003 base Vibe with five speed manual. Been in the 20's the last few days here in Ohio. Moved the wifes Vibe and it idles about 1500-2000 rpm cold. Lasts just a few minutes, but that seems rather high.That is with trans in neutral and clutch in or out....What are the rest of you experiencing
ragingfish
Re: Cold Idle Speed... (sevenofnine)
Post by ragingfish »
Sounds about right to me.Cold is in that area, warm should drop to below 1000.
2009 PONTIAC G8
NSimkins
Global Moderator
Post by NSimkins »
That's normal... check out these threads, should help you out:http://forums.genvibe.com/zerothread?id ... ad?id=1186
ArcsVibe
Post by ArcsVibe »
It is the normal idle speed for the Vibe...my friend has a 2003 Corolla and it is the same thing...nothing to worry about.
Genvibe Global Moderator
MOTM September 06 & July 09
VOTM April 06
Matrix XR 2010 (5-09-2014)
sevenofnine
Re: Cold Idle Speed... (NSimkins)
Thanks for the quick replies. Glad to see it is "normal".
Jahntassa
Post by Jahntassa »
Normal. Even my old Ford Probe would idle high for the first couple of minutes when it was starting up cold. It's just trying to get everything flowing and get warmed up..
