What is the"L" in VVTL-i: What is happen in the Engine?
Train Man
Post by Train Man »
What is the"L" in VVTL-i Yes, yes i know it stands for lift but what exactly happens in the engine? I have found no real good explanations. Does anyone know, what would be really great are some technical documents about this. How does it change the lift? Any info along these lines would be great. Thanks Train Man
ragingfish
Re: What is the"L" in VVTL-i: What is happen in the Engine? (Train Man)
Post by ragingfish »
I think these links may hold the answer your question:http://www.corollaperformance.....htmlhttp://www.newcelica.org/other...i.htm
2009 PONTIAC G8
NSimkins
Global Moderator
Re: What is the"L" in VVTL-i: What is happen in the Engine? (ragingfish)
Post by NSimkins »
rasermon
Re: What is the"L" in VVTL-i: What is happen in the Engine? (NSimkins)
Post by rasermon »
Some more info. just posted the other day. http://forums.genvibe.com/zerothread?id=7281
Satellite 03 GT Retirement ----> Moderator for Genvibe.com 2002 - 2007 A fact of life: After Monday and Tuesday even the calendar says (removed)
Stang2Vibe
Post by Stang2Vibe »
So wait, after reading that stuff you mean to tell me that when the engine is operating in non-lift mode that it uses all 16 valves but when lift is engaged, it is only using 8? That's what I'm getting from these explanations. And how does cutting the number of valves being used in half for the sake of keeping the ones that are operating open longer make such a dramatic increase in HP? It would seem to be about an even trade.
goodvibe
Re: What is the"L" in VVTL-i: What is happen in the Engine? (Stang2Vibe)
Post by goodvibe »
Try this one. You wont find a more concise explanation of the 2zz drive train. http://russ.angrypacket.com/celica/
