Rotrex supercharger installed in Celica.
Supercharger, turbo, nitrous, and anything that has to do with forced induction
d_m_kolb
Post by d_m_kolb »
I thought members might like to see this info. The system looks great.Click here
LocDog
Re: Rotrex supercharger installed in Celica. (Admin II)
Post by LocDog »
But will it fit the vibe....
-aBySS Monotone Vibe-Auto Everything (I wanted a manual)-Moons and Tunes-No Badges-No Lateral Bars-Sony CDX-M730 Head Unit-200w PPI Amp Powering a 12" MTX Sub-9 1/2'' Stainless Steel Trumpet Air Horn-Spare Bridgestone Blizzaks Mounted on the Cheapest Steel Rims Ever
d_m_kolb
Re: Rotrex supercharger installed in Celica. (LocDog)
Post by d_m_kolb »
Not sure. It was as you can see installed on a Celica. I have e-mail the manufacturer and am waiting on a reply.
Flip-Side
Post by Flip-Side »
I would love to put on a turbo or super charger...but wont they eat up a stock engine and trans? What do I need to do to them so the Chargers can be used without hurting my baby. I know next to nill bout them cause a dual carb v8 was always good enough for me before the vibe.
OlacMoonpilot
Re: Rotrex supercharger installed in Celica. (baddkkarma)
Post by OlacMoonpilot »
Hi ThereThe supercharger detailed above is on my car, its been developed as a kit for the Toyota Celica VVTi and should soon be available for that car.Unfortunately we don't get the Vibe in the UK so we are a bit stuck as to how to check and test this out. A couple of things might well help, for a kick off a picture of the engine bay would be useful, perhaps one of the bay in general, and a more detailed shot of the left hand front portion, where you can see my charger is mounted. Also if someone can get the part number for the alternator that would also be a big help.What I would like to do is take a look at these pictures and see what the bay is like, if its a definite no chancer it should be fairly obvious.After all, we have done a lot of work on the 1ZZ, mine is in bits in my garage at the moment waiting for a set of bearing shells to arrive, I know this engine inside out, quite literally Any help could end up being good for you.Cheers
2000 Toyota Celica VVTi supercharged 1987 Toyota Celica 2.0GT 1986 Toyota Supra 3.0i Celica Club UK Japspeed Racing
d_m_kolb
Re: Rotrex supercharger installed in Celica. (OlacMoonpilot)
Post by d_m_kolb »
First off thanks for joining the site!Here are some engine bay pics of the 1ZZ. Thanks to our moderator (NSimkins)
OlacMoonpilot
Ok, thanks for the pics.Initial observations, at the front left of the engine bay there is a tube with a rad cap on it, I presume this is for filling the coolant via the radiator? If so is this fixed in place or is it a bolted on tube?Secondly it looks like the aircon pipes would be in the way, especially the one on the left that loops in over the belts.It doesn't look like the standard bracket we use would fit, although the mountings would almost certainly be the same, these points above my well stop it from fitting.Could someone measure the distance from the front edge of the alternator to the first thing on the front slam panel, probably the fans on the radiator, as straight a line as possible, it'll give me rough idea of the area we have to work in.Also a measurement from the top back of the cam cover to the front scuttle would be useful, it looks like you have a much larger space to work in there so it could be possible to mount the charger at the back of the engine instead.Many thanks
NSimkins
Global Moderator
Post by NSimkins »
Please forgive me if my terminology is rough or inaccurate. If you need more information than what I am presenting, please let me know and I will do my best.quote:Initial observations, at the front left of the engine bay there is a tube with a rad cap on it, I presume this is for filling the coolant via the radiator? If so is this fixed in place or is it a bolted on tube?Yes, that is what I would assume also. The tube is fixed into place and integrated onto the radiator. Click the thumbnail picture below to see a detailed image with dimensions and some other information directly typed onto the image.NOTE: If you are using later versions of Internet Explorer, you may want to disable (uncheck) the "Enable Automatic Image Resizing" option under Tools>Internet Options>Advanced tab>Multimedia area. These images are rather large and are best viewed at their maximum (100%) sizing.quote:Secondly it looks like the aircon pipes would be in the way, especially the one on the left that loops in over the belts.Yes, it goes directly over the belts to the back of the engine bay.quote:Could someone measure the distance from the front edge of the alternator to the first thing on the front slam panel, probably the fans on the radiator, as straight a line as possible, it'll give me rough idea of the area we have to work in.See the thumbnail listed above for those dimensions.quote:Also a measurement from the top back of the cam cover to the front scuttle would be useful, it looks like you have a much larger space to work in there so it could be possible to mount the charger at the back of the engine instead.Click the following thumbnail for measurement details on this area:If you need more measurements, let me know.
OlacMoonpilot
Re: Rotrex supercharger installed in Celica. (NSimkins)
Thanks for that, I am awaiting a new style of SC to come from Rotrex, once I have it I'll know a bit more about the fitting in this car. Front of the engine like on my car is a definite no chance though, I am thinking rear of the engine at the top betwenn the head cover and the bonnet.
d_m_kolb
Post by d_m_kolb »
Because I know some one is going to ask what the heck is a bonnet I'll just explain now. It's the hood. They call the hood of the vehicle a bonnet over in the UK.
ride2envy
Post by ride2envy »
How much is this Rotrex kit for the celicas going for? I have a 01 GT and might be interested..... laters
