bolt patterns
SkateForLife86
bolt patterns
Post by SkateForLife86 »
Ok, so i'm an idiot, i don't know how to really use the search 'feature.' But besides that, could someone really help me out by telling the bolt pattern for the vibe, I just have to double check and make sure what i have is correct, 5X100. And someone with aftermarket rims, is thereany problems with the new rims, do u need anything special because of a different bore or anything?thanks again
Geo
Re: bolt patterns (SkateForLife86)
Post by Geo »
5x100 is correct!don't need anything special. I just took off old wheels, put new ones on, and bolted them on. I forget the torque rating though, you might want to search that one up.5+ thousand trouble free miles on my new wheels too! :D
BADGER PRIDE
cohocarl
Post by cohocarl »
Offset should be 38mm if I recall. I think I remember some guys on Matrixowners were using 40mm, but I could be mistaken.Manual says lug torque is supposed to be 76ft/lbs.
Sold 6/16/04 03 Vibe 5-speed, Hotchkis Sway Bars & Springs, Hooker Aerochamber, Panasonic Stereo, Hitch, Silverstars,04 Saturn Vue 2.2L Ecotec, 5-speed, 01 Stratus R/T Coupe 5-speed (wife's car) 85 Corvette 268 CompCam, 882 heads, FlatTops, 24lb injectors, Hooker Aerochamber true duals, 58mm TB, Holley AFPR, Siamesed intake base, Polished TPI.
ragingfish
Re: bolt patterns (cohocarl)
Post by ragingfish »
Quote, originally posted by cohocarl »Offset should be 38mm if I recall. I think I remember some guys on Matrixowners were using 40mm, but I could be mistaken.Manual says lug torque is supposed to be 76ft/lbs.That's all?I figured it would've been in the 100's...
2009 PONTIAC G8
rasermon
Re: bolt patterns (ragingfish)
Post by rasermon »
Quote, originally posted by ragingfish »That's all?I figured it would've been in the 100's...I called Discount Tire during the summer and they looked up the torque specs. There computer also recommended 100ft/lbs. When I rotated my wheels I followed the GM specs of 76ft/lbs.
SkateForLife86
Re: bolt patterns (rasermon)
thanks again for thefast resonses, u guys r the best
cohocarl
Post by cohocarl »
Quote, originally posted by rasermon »I called Discount Tire during the summer and they looked up the torque specs. There computer also recommended 100ft/lbs. When I rotated my wheels I followed the GM specs of 76ft/lbs.The 50 times I was at Discount last summer with the problems I had with the wheels I bought from them, I always had to tell them to tq it at 76 because their "chart" didn't have a Vibe listed, so they just used "Pontiac", and it showed 100lbs. The last time I was there and had my original steel wheels re-installed, I actually had a 1/2 way intelligent guy doing the job. He was very careful, and after I told him the tq should be 76, he politely asked to see the specs in my manual because he didn't want to tq them too low. He definately won't stay there long...(meaning he's way overqualified to work there seeing he was smart and careful)
