Is it necessary to get a camber kit with springs that drop as low as 2" or lower i.e. sportlines. Or is a four wheel alignment after the installation enough?thanks
When they check your alighnment they will tell you if you need a camber kit to bring it back to within spec! Maybe maybe not
Abyss Monotone Power Package All exterior lights upgraded to Piaa 60 Series Flowmaster, K&N Typhoon Autometer liquid filled oil pressure guage 5% Tint on all five rear windows Hurst Pistol Grip shifter, Piaa Sports Horns
Since the Vibe (non-AWD anyway) rear suspension is a trailing swing arm, the camber does not change with ride height, thus any need for a camber kit to correct same would not relate to lowering springs, just factory variations, impact damage, etc.
