I posted here a few weeks ago, regarding 'gravel in the radio', and a check engine light on a new Vibe, purchased on 09/14. It's been mostly down hill since then. I'd like to know if any of you have had similiar experiences, or heard of others that have.09/18 - 09/20: 1st visit, waited for a new radio, check engine light was reset.09/24, 2nd visit: Ordered a coil assembly, and swapped suspect from #1 cylinder (#1 Cylinder Misfire was computer code) to #2, for diagnostic purposes.09/30, 3rd visit: Light on again, coil in from factory. Replaced coil, reset light, sent home.10/02 - 10/3, 4th visit: Light on again. While dropping car off, I asked about the computer code on prior visit, and if they replaced the coil on Cylinder #1, or #2, and what the code actually was. They stated that it was still #1 misfire. I asked why then, did they once again replace a coil assembly when they had already eliminated that by swapping it with #2. The service rep agreed that it was a bit pointless. They also sprung for a rental car this time.Rep called at home later that night, and said they'd taken a new car off of the lot, and used it's fuel injector rail, coil packs, and computer module, and put into my car. They would drive it home that night, and back in the morning, to make sure it was okay.I went to pick it up, and they pulled the car out front. I hadn't gotten my seat moved back to where I want it when I noticed the light was on again.They still have the car, for what I would consider the 5th trip. A factory guy is being sent up, he's supposed to be here Monday. If he can't get it fixed the first time, I'm probably going to do the lemon law thing. If you live in Washington, checkout
http://www.wa.gov/ago/consumer/lemon/ Other states should have similiar sites setup, very informative on what you can/can not do regarding lemon law issues.Thanks guys, it's nice to be able to rant a bit. I'll keep you posted on what happens with the car.Paul
