Eibach Pro Springs or Progress Sport Springs or ?
YoYo
Post by YoYo »
My local firestone says they will swap out the springs from the assemblies for $100. I'm pretty confident about removing /reinstalling them all in the car - it was that spring compressor that was the worry for me. With that, I'm gonna get springs. But which ones?The Eibach's drop it 1.5 the Progress ones 2.1. I like the idea of the deeper drop. Does anyone with these sets installed have anything positive/negative so say about them (recomending one over the other)? For background, I've owned a Mustang GT and Miata before - so I'm used to a fairly harsh ride. I don't want to have it beat me to death though!
Black 03 Vibe GT 6spd
Sub-Vibe-R
Re: Eibach Pro Springs or Progress Sport Springs or ? (YoYo)
Post by Sub-Vibe-R »
I've got Tein spring and they are very good.Droped the front of 2,5" and 2,25 at back.For $105 a set, it worth it
Flip-Side
Post by Flip-Side »
I have heard only good things about both Hotchkis and Eibach springs. If you want a bigger drop from Eibach, you can get the Sportline instead of the Pro-kit springs. I have always heard mixed setiment about Progress springs, but someone with them installed on a vibe or matrix might be able to give you a better idea. Hope this helps. The posts below will give you a good look at, and opinions on the different springs. Thanks to all the people who made some great install posts. Heres some good posts discussing the different springs. http://forums.genvibe.com/zerothread?id=5423 http://forums.genvibe.com/zerothread?id=4502 Progress installed http://forums.genvibe.com/zerothread?id=5543 Eibach installed http://forums.genvibe.com/zerothread?id=2187 http://forums.genvibe.com/zerothread?id=4452 Hotchkis installed http://forums.genvibe.com/zerothread?id=5497 http://forums.genvibe.com/zerothread?id=4164 TRD installed http://forums.genvibe.com/zerothread?id=3889 Ground Control installed http://forums.genvibe.com/zerothread?id=3546 Tein installed http://forums.genvibe.com/zerothread?id=6278
viberator
Re: Eibach Pro Springs or Progress Sport Springs or ? (Flip-Side)
Post by viberator »
I am looking at a set of Tein's on racingworks.com for $142. I am not sure if the rated 2.6" drop on front and 3.4" on rear is too much or not... REDTRDMATRIX.com has a matrix w/ Teins but they look no where near as low as a Salsa vibe I saw, it might even be yours Sub-vibe-R. so i am skeptical, whether I should go for the $142 Teins that I hear so much about or go w/ $250+ Eibachs that also seem like a good brand. Any comments appreciated, any better pricing anywhere greatly appreciated!!!! pictures help lots as well, if possible!!!
18x8.5 inch Bronze Falken Hanabi Rims, 235/40/18 Falken Ziex Tires, Factory upgraded front spoiler, AEM short ram intake,DC sports ceramic coated headers, magnaflow high-flow catalytic converter, Greddy 2.5 inch axle-back exhaust and midpipe,Tein S-Tech lowering springs, Progress rear anti-sway bar,DC sports Carbon Steel series twin bar strut tower brace, Fidanza flywheel, Spec stage 2 kevlar full disc clutch,Speed Source Brass Shifter-link bushings
rasermon
Re: Eibach Pro Springs or Progress Sport Springs or ? (viberator)
Post by rasermon »
Well done Flip on your post.quote:I am looking at a set of Tein's on racingworks.com for $142. I am not sure if the rated 2.6" drop on front and 3.4" on rear is too much or notAccording to there web page. The Tein springs are 2.3" drop for both front and back. I see the Tein's come with silencer sleeves. That helps to cut down on noise from the springs touching one another on the first two coils. I have installed Hotchkis springs on two vibes, the only problem is the bottom 2 coils (front) touch one another making a soft clunking sound over small bumps. After a couple weeks it seems that most of the spring noise is gone.
Satellite 03 GT Retirement ----> Moderator for Genvibe.com 2002 - 2007 A fact of life: After Monday and Tuesday even the calendar says (removed)
NY Pete
Re: Eibach Pro Springs or Progress Sport Springs or ? (rasermon)
Post by NY Pete »
I have the Eibach Sportlines (2" drop) and have never heard this spring noise you speak of... Pete
'02 Jetta 1.8T Silver Arrow/Black Leathuh - Neuspeed turbo inlet pipe, 17" VW Exor wheels, euro Bora tails, Neuspeed Sofsport Springs, Bilstein HD's, Da'lan hitch'03 20thAE GTI #3494 Imola Yellow/Black Recaros - Omori/AWE boost gauge, HPA Motorsports Short shifter, Neuspeed 28mm rear sway, REVO programming, Neuspeed turbo inlet pipe, FK Badgeless grille, Kamei eyelids and one big fat grin
ragingfish
Post by ragingfish »
I bought a set of Tein S.Tech springs, 2.3 Front 2.1 Rear for $100. Unfortunately, I still haven't had them installed.
2009 PONTIAC G8
MadBill
Re: Eibach Pro Springs or Progress Sport Springs or ? (ragingfish)
Post by MadBill »
I too bought/installed Tein S springs. The drop was ~2-1/4". They rode great, the drop looked just right, no noise, etc. (did not come with any sleeves or anything) Unfortunately, the drop was a bit much for my way-oversize 275/40 x 17"s, so I pulled them out and just trimmed the stock springs 1/2 turn.Re installation, I'd say 65 -70% of the work was the re and re of the struts; the spring compress/replace was pretty simple with a rental compressor. (mine was free from Canadian Tire)
Stang2Vibe
Re: Eibach Pro Springs or Progress Sport Springs or ? (MadBill)
Post by Stang2Vibe »
Come to think of it, I think Advance Auto will supply you with free loaner tools as well (such as a spring compressor). Not 100% sure on that, though.Also, I'd like to hear some current opinions on the Ground Controls. They are the ones I am most interested in so far. Positive and negative comments about them are equally appreciated.
rasermon
Re: Eibach Pro Springs or Progress Sport Springs or ? (Stang2Vibe)
Post by rasermon »
quote:Come to think of it, I think Advance Auto will supply you with free loaner tools as well (such as a spring compressor). Not 100% sure on that, though.AutoZone has a "Loan-A-Tool Program". You can rent there Strut Spring Tool for $42 plus tax and keep it as long as you need it. Return it and get all your money back.
Sub-Vibe-R
quote:I am looking at a set of Tein's on racingworks.com for $142. I am not sure if the rated 2.6" drop on front and 3.4" on rear is too much or not... REDTRDMATRIX.com has a matrix w/ Teins but they look no where near as low as a Salsa vibe I saw, it might even be yours Sub-vibe-R. so i am skeptical, whether I should go for the $142 Teins that I hear so much about or go w/ $250+ Eibachs that also seem like a good brand. Any comments appreciated, any better pricing anywhere greatly appreciated!!!! pictures help lots as well, if possible!!! I installed Tein on my Vibe and they dropped it of around 2,5" front and 2,25" rear. No noise, just a good drop, a good ride too and a very good look.And $142 looks little expensive for me. I got them from e-bay for $105 + shipping ($35 if I remember)
Thxalot
Re: Eibach Pro Springs or Progress Sport Springs or ? (Sub-Vibe-R)
Post by Thxalot »
I picked up Eibach Pro-kits at Adventon.com They were under $200. Best price I could find anywhere.If you care about giving your car that "lowered cool look" don't by the pro-kit springs. The drop is very subtle. Even parked right next to a stock base Vibe, my GT wasn't obviously lowered. The tire:wheel well spacing is totally even all around. Lowered cars usually have more gap on the sides of the tire than at the top. The stock Vibe/Trix has more gap at the top than the sides which lends it that mini-SUV quality. Even more so on the AWD.A lot of people looking for significant drop are disappointed with the Pro-kit springs. But since they are the same ones used by TRD, you can rest assured that they give you the optimal balance of ride and handling, in addition to strict quality control. I don't know about the progress springs, but if I was looking for more "flash" than "dash", I would go with the Sportlines from Eibach.If you want performance, get the TRD/Pro-kits. My car soaks up regular bumps with no problems. There is no bouncing, hobby-horse effect, and for light bumps it is even smoother than stock, especially at near triple digit freeway speeds. Big potholes and sharp speed bumps transmit more impact than the stock springs used to. But I don't have any bottoming out problems and very rarely need to slow down for drainage ditches.The handling differences after putting in the springs and the Progress AR bar are dramatic. Sucker is much tighter. Still understeers and has trouble powering out of turns, but it's tough to make a FWD car truly neutral. Although not F1 race-car flat, there is dramatically less body roll with on-ramps, acute turns, and sweeping corners. It's also a lot more fun to drive now.I did the install myself, but the disassembly and reassembly of the struts was a real pain in the a$$. $100 is worth it to have your shop do it. Mine wanted $400 for the whole job. Car & Driver spent $550 getting TRD springs put on a Camry at a Toyota dealer. So you can really save a lot with DIY.-Burt
Vibe GT: 225x45x17 Michelin PS2s on OZ Racing Rims | Eibach/TRD Springs | Progress Antiroll Bar | GMD Exhaust (pulled due to freeway drone) | G2 Painted Calipers'02 Audi A4 Avant Quattro | 3.0L | 6-speed | bone-stock'90 ZR-1 375 HP | 375 ft-lb | 4.6s 0-60 | 176 MPH
meathead333
Post by meathead333 »
quote:I've got Tein spring and they are very good.Droped the front of 2,5" and 2,25 at back.For $105 a set, it worth ithey whered you get them at?? i tried to IM you but it wasnt working...thanks
My myspace.com profile My 73' Bronco Cardomain page
YoYo
Re: Eibach Pro Springs or Progress Sport Springs or ? (Thxalot)
Post by YoYo »
Thanks to all for all the information here! I gonna go with the Pro-Kit ones even though the drop is not as low, I've not read a post about them that was not positive in most all reguards (handling, sagging, etc).Thanks again to all the responses!
Sub-Vibe-R
Re: Eibach Pro Springs or Progress Sport Springs or ? (meathead333)
quote:I've got Tein spring and they are very good.Droped the front of 2,5" and 2,25 at back.For $105 a set, it worth ithey whered you get them at?? i tried to IM you but it wasnt working...thanksE-bay my friendI found 2 sellers I bought mine from this seller, fast shipping, good serviceI saved $10 on shipping to Canada and he does not need a confirmed address (which I cannot have in Canada)http://cgi.ebay.com/ebaymotors/ws/eBayI ... =33582$105 + $30 shippinghttp://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2441687574&category=33582$105 + $30 shipping and $5 insurance
meathead333
anyone know why people can have the same car with the same springs but have different results in how much they dropped the car?
Sub-Vibe-R
It is hard to say. May be it depends on the stuff loaded in the trunk...On the Tein web site, S-Tech should give a frop of 2.3 front and 2.1 rear.JDMTOUCH sais the same as Tein and AJDN claim 2.3 and 2.1.Personally, I've got 2.25 front and 1.75 rear. But those mesure were not very accurate and they are close to the Tein mesures.May be if I mesure my drop again (after allignement and some km put on them) those number could change a little bit.
dmitri
Post by dmitri »
i got the package at ptuning. look under the progress spring link thats me...i still love it
MadBill
Post by MadBill »
I'd say:1. Some people don't remember to take good "before" measurements, so they have to guess a bit.2. Sometimes the springs are not fully seated when installed and take some mileage to settle in.3. Both the old and the new springs have a certain + - tolerance, so the change in height can vary.
