With the lowering spring, the suspesion is harder. The car roll less while cornering. But it could have difference between the differand bran of spring.
quote:have you noticed an increase in the pogo effect of is the vibe steady ans smooth? No matter what springs you use, there is always going to be a forfeit of ride quality on harsher surfaces. It is one of the reasons upgrading your shocks is a good idea when you lower your car. Others I've heard on genvibe say there is a slight bouncing on harsh road, and the stock shocks can only do so much with less travel due to the shorter springs.
quote:have you noticed an increase in the pogo effect of is the vibe steady ans smooth? No matter what springs you use, there is always going to be a forfeit of ride quality on harsher surfaces. It is one of the reasons upgrading your shocks is a good idea when you lower your car. Others I've heard on genvibe say there is a slight bouncing on harsh road, and the stock shocks can only do so much with less travel due to the shorter springs. The wheel hop seems to be a little more present since I installed my spring. I don't know if it is only because my driving style has changed or it is related...
quote:have you noticed an increase in the pogo effect of is the vibe steady ans smooth? No matter what springs you use, there is always going to be a forfeit of ride quality on harsher surfaces. It is one of the reasons upgrading your shocks is a good idea when you lower your car. If someone were to upgrade their shocks, what would be the best to get?
I've never considered the Vibe steady and smooth. It's always been a bit firm. When I added the TRD springs, I noticed a bit firmer ride, but the MAJOR benefit is the MUCH better high-speed stability. Darn car cruises at 90-100mph and feels rock solid.
'03 Vibe GT monotone silver/black interior, 17 inch wheels, 6-disc changer, power packageMods: AEM intake, TRD springs, A-spec Strut Bar'01 Corvette Coupe silver/black interior, six-speed, Z51, a few mods, 12.29 at 117.3mph in 1/4 mile on street tires.
Well SEMA was just here in Vegas and I missed due to work and med school. but i heard they are presenting new aftermarket parts for the Vibe/Matrix owners....we will just have to see
2003 Mono Abyss GT,Moon and Tunes17 " Sport Max 929, Eibach Pro SpringsDunlop 215 50/RZ17 tires oem, Coustic 601SE amp, 2 CF1044 10" GM Top Rear Spoiler, Optima 51R Yellow TopAEM Short intake Blue, Progress Rear Anti Roll barFlowmaster Delta Flow 60 Series, Ground wiresDenzo IK 20 5304 plugs,TRD STB Front, Brass Bushings
