squeaky sound coming below the Re-circulation button.
Dan
Post by Dan »
Hello, I've got a little bit more than 1 000 miles on my vibe and I notice a squeaky sound a little bit under the recirculation button. (I'm not talking about the sqeaky sound that is comming from the dash (instument panel) that was already discussed in this forum... I don't have this problem) When I push with my tumb near this location (on the plastic area) , it's strop. Have someone else have the same problem ? And if yes, How we can solve this problem ?? Do we do like the sqeaky sound that some have on the dash ? I.e. Remove the plastic and try to put something there ?Thanks
Base 5 speed Satellite Orbit Remote Starter/5Doors
NSimkins
Global Moderator
Re: squeaky sound coming below the Re-circulation button. (Dan)
Post by NSimkins »
quote:Have someone else have the same problem ? And if yes, How we can solve this problem ?? Do we do like the sqeaky sound that some have on the dash ? I.e. Remove the plastic and try to put something there ?I have the same problem, but it doesn't occur all the time. Seems to do it more when the temperature is below 50 degrees (F).You could try to pull out the silverish bezel and put some thin foam or something behind it and see if that helps. I haven't had the time lately to investigate that particular squeak, but when I do I will let you know.The silverish bezel pulls out from the bottom, angle the bezel up and pull out from the top to get the entire bezel off. Doesn't take much force to remove.See here for pics on removal: http://forums.genvibe.com/zerothread?id ... =5780#5780
Dan
Re: squeaky sound coming below the Re-circulation button. (NSimkins)
Post by Dan »
Thanks for the answer NSimkins !I will try that and see if it's help !
