Trust me it will take you a few moments to put them on! This coming from a person who has zero patience with things like that!Check out my car and you will see that I did a decent job, and so can you!
Genvibe Global Moderator
MOTM September 06 & July 09
VOTM April 06
Matrix XR 2010 (5-09-2014)
Just like doing window tint. Spray some window cleaner down first so that it will move easily without sticking too bad. Squeeze and let dry. You could even let a 10 year old do it. Now you will feel bad if you do not do it yourself.
Just here to lend a hand to people who have questions about their Vibe.
Got these stickers too, hope mine stick...soapy water eh keeps it from sticking then you sqweegy it out with no bubbles then use hair drier to mold sheech no wonder there is a disclaimer if you screw up...maybe crazy glue will work for me haha. Seriously I hope mine turn out got the red ones and can't wait to get them on.
2003 Supercharged 5spd Vibe BaseGM Supercharger + TRD ECUMagnaflow Cat Back + DC Sports Header 18" AXIS rimms w/Kumho TiresTop Spoiler + Vis CF Functional Scoop
Have you in the past armoralled the dash or put any protectant on it?If so this will make it not stick!!!Get some regular rubbing alcohol and wipe the area off many times with new cloths each time. hopefully this will get it all off. It is the only easily available cleaner that will not harm anything or leave a residue that will make things not stick.Next get a spray bottle and put 2-3 (NO MORE) drops of dish washing liquid. without any aloe or lotion or any additives in it!! Fill with water and shake well. this should only have about 1/2-3/4" of suds. if more pour some out and refill with water till it has this much suds.Peel backing off stickers, spray dash, and back of BARE VINYL ONLY, NOT THE PAPER BACKING, apply sticker and rub it down, get a hair dryer and go slow.Gently remove any transfer tape if it has any rerub it down, don't sweat if it peels up slightly. just peel it off the transfer tape and apply by hand slowly. Rub it down and heat it sown.IT WILL BE OK!!!!!
05 Platinum Vibe GT, Moon & TunesHotchkis 2" Drop SpringsHotchkis Front & Rear Sway BarsSun Hyper Voltage System & Ground WiresMagnaflow Cat Back ExhaustTenzo 18" Overdose WheelsPlasmaglow LED Undercar LightsSoon to be the Wildest Vibe Alive!!!http://www.street-graffiti.com...m.htm
