quote:I am thinking about some subs for the back area. I have a friend who says kicker makes these 12" L7 solarbaric that rock, i need two and they are square. This is true, find info here.
http://www.kicker.com/ShowPage.cfm?file ... OFERSquote: I also will need to know about the ohlm situation right? They list these things with dual ohlms, like 2,4, and 6 ohlms, which do i need? Alright, they come in two varieties. 2 Ohm DVC (Dual Voice Coil), or 4 Ohm DVC. Which (as far as I know), means you need a 2 Channel amp that'll support 2x2 or 4 Ohm. Now.. These present many issues as there are two coils, which means that each speaker needs two channels of amp, or you can wire it together and do it in mono. IE, a 2 Ohm DVC would parallel to 1 Ohm, or Serial to 4 Ohm. It all depends on how you want to wire it.quote: I also will need a amp or two right? which size will be the best for two of the L7's, and which cross over will work for me? Does anybody have a source for these speakers, i need some expert advice here, i don't want to spend money on the wrong stuff. Alright...Overall, you should only want one of these things. Unless you want to upgrade A LOT. These subs need 750 Watts RMS, and that's a pretty darn big amp. If you want to run two of these, that's around 1600 Watts RMS...which means you'd need to get a bigger alternator, better battery, and the wires and Capacitors to power it all! Granted, I like the idea. Heh.If you have the money to do it all, then that's great. These things will take up a lot of room though, so make sure you're willing to give up the space. If you want to go through more details, i'll be happy to help. Either in this thread, or in PM.Though, i'm sure there are other members that'll probably be better at it.. I'd like to try..I know a thing or two, but i'm always too broke to go all the way..
