Hello fellow Vibers,
Was parked for about 10 minutes with the car running and the temp gauge decided to show off and shoot up like it lives under a bridge downtown.
My vibe is a 2007 Base with the 5SPD manual and according to every auto parts store (local & online) the radiator fan is different between the ATX and MTX models. Yet, if you look up the same year Matrix and/or Corolla, the radiator fan is literally the same regardless of the transmission option.
If you look up the fans, the MTX version is about $200 or better but the ATX version is roughly $80. However, since the MTX version wasn't available, I went to a local u-pull yard, pulled one out of a 2005 Corolla MTX and slapped it in with zero issues.
For whatever reason, the part number is the same for all the below models EXCEPT the base manual version of the Vibe...but trust me, it'll work if you have a manual Vibe like myself.
So this is just an FYI in case anyone runs into an issue trying to locate the radiator fan assembly for a 2003 - 2008 Vibe with a manual trans.
Dorman - 620-546
2008 Pontiac Vibe Base Submodel; Automatic Trans.
2008 Toyota Corolla
2008 Toyota Matrix Manual Trans.
2007 Pontiac Vibe Base Submodel; Automatic Trans.
2007 Toyota Corolla
2007 Toyota Matrix Manual Trans.
2006 Pontiac Vibe Base Submodel; Automatic Trans.
2006 Pontiac Vibe GT Submodel; Manual Trans.
2006 Toyota Corolla L4 1.8L (1794cc)
2006 Toyota Matrix Base Submodel; Manual Trans.
2006 Toyota Matrix XR Submodel; Manual Trans.
2005 Pontiac Vibe Base Submodel; Automatic Trans.
2005 Pontiac Vibe GT Submodel; Manual Trans.
2005 Toyota Corolla L4 1.8L (1794cc)
2005 Toyota Matrix Base Submodel; Manual Trans.
2005 Toyota Matrix XR Submodel; Manual Trans.
2004 Pontiac Vibe Automatic Trans.
2004 Toyota Corolla
2004 Toyota Matrix Base Submodel; Manual Trans.
2004 Toyota Matrix XR Submodel; Manual Trans.
2003 Pontiac Vibe Automatic Trans.
2003 Toyota Corolla
2003 Toyota Matrix Base Submodel; Manual Trans.
2003 Toyota Matrix XR Submodel; Manual Trans.
