2009 Vibe AWD rear axle seals unavailable
redseed
Post by redseed »
It seems these parts have been discontinued. Can anybody confirm that the Toyota Matrix part will work?
Thank you!
SeattleJeremy
Re: 2009 Vibe AWD rear axle seals unavailable
Post by SeattleJeremy »
redseed wrote: ↑Thu Dec 14, 2023 8:07 pm Can anybody confirm that the Toyota Matrix part will work?
Yes, I can confirm the Toyota Matrix part will work. The suspension and driveline parts for the two cars are identical.
redseed
Post by redseed »
SeattleJeremy wrote: ↑Mon Dec 18, 2023 12:24 pm
Thank you so much. I assume the rear pinion seal that we now have to replace is the same. Toyota part is the only one available.
123watchdog
Post by 123watchdog »
Good afternoon. Thank you for sharing this post. Could either of you please confirm the part numbers for the rear transfer case seal for a 2009 Pontiac Vibe AWD 2.4L 4 speed automatic? The terminology between GM and Toyota is slightly different. I am not a mechanic.
Are these part numbers correct?
GM Part: GM 88974583 Seal,Transfer Case Rear Extension
https://www.gmpartsgiant.com/parts/gm-s ... &filter=()
Toyota Part: Part Number: 9031138090 SEAL, TYPE T OIL (FOR TRANSFER EXTENSION HOUSING)
https://www.toyotatownpartsdirect.com/p ... 38090.html
Or could it be This Toyota Part Number: 9031155002 SEAL, OIL (FOR TRANSFER CASE)
https://www.toyotatownpartsdirect.com/p ... 16822/9031
Toyota Diagram of Transfer Case & extension housing:
https://www.toyotatownpartsdirect.com/a ... 52460.html
Thank you!
Toyota Diagram - Transfer case & extension housing.pdf
(194.65 KiB) Downloaded 307 times
