Hi all.
I have a 2003 base vibe with 225k miles. It vibrates more than I would like at idle. The vibration is diminished but still present in park and neutral.
There is a lean running code although the vibrations may have started before it. I’m not sure because the evap codes I ignore leave the check engine light on.
The car drives well and the idle rpms look normal, although on rare occasions it stumbles at low speed. probably the product of a small vacuum leak that is also causing the code.
Before I go down the road of pcv valve, iac, maf, vacuum leaks, is there any way to rule out the torque converter?
Thank you for reading
