2005 dash cluster warning lights, question=-
jamesmetairie
Post by jamesmetairie »
Just had thermostat and radiator fan assembly replaced. Noticed on a short road trip just below the check engine light there is a light that appears often at higher speeds. then disappears. No symptoms other than the light. It looks like a circle with a handle on top. And all around it has small lines reaching outward. it is color yellow. About 1 inch below cel and slightly towars the center of that instructment .
Re: 2005 dash cluster warning lights, question=-
I haven't seen an '05 cluster in person but it sounds like it could be the headlamps on indicator.
jamesmetairie
thanks.
and while I was on that short road trip I had a sweat rag laying on the dash on top of the sensor for dlr lights.
So no malfunction.
