Starts consistently. But then stalls after 45-60 seconds regardless of how much gas I give it. Can just let it run and it will stall, or give it gas and still stalls. Check engine light come on. Ignition coil A,B,C and you guessed it….D
I’ve replaced all 4 (and even took one back and got it replaced.
I’ve replaced the throttle body position sensor, the cam shaft sensor. Swapped out the PCM.
Any thoughts or suggestions??? Thanks
