Fuel line leak
ZZvroom
Fuel line leak
Post by ZZvroom »
2003 GT
One of the fuel lines forward of the LR wheel has a tiny chink missing from it. It seems to be line #3
https://www.wholesalegmpartsonline.com/ ... ct=3092072 but those appear to be
unavailable.
I looked at the Matrix list http://www.genvibe.com/images/misc/manu ... atalog.pdf but it seemed to say it's a 77209-02060, except that's not shown as a Matrix part.
We kludged a fix for now, but.....
I'm unfamiliar with these plastic fuel lines and the connectors used on them.
How do you remove/install them?
Are there universal replacements available?
Images at https://photos.app.goo.gl/MjQNcJdwbYBc6XYu5
Re: Fuel line leak
https://www.toyotapartsdeal.com/oem/toy ... 02060.html
says toyota part # 77209-0206 fits
2003-2005 Toyota Corolla CE, LE, S, STD, XR, XRS|4 Cyl 1.8L 1ZZFE, 2ZZGE; 1ZZFE, 2ZZGE; ZZE130L-AEMDKA, ZZE130L-AEMNKA, ZZE130L-AEPDKA, ZZE130L-AEPDKK, ZZE130L-AEPNKA, ZZE130L-AEPNKK, ZZE130L-DEMDKA, ZZE130L-DEMDKK, ZZE130L-DEMNKA, ZZE130L-DEMNKK, ZZE130L-DEMSKA, ZZE130L-DEMSKK, ZZE130L-DEPDKA, ZZE130L-DEPDKK, ZZE130L-DEPNKA, ZZE130L-DEPNKK, ZZE130L-DEPSKA, ZZE130L-DEPSKK, ZZE132L-DHMDKA, ZZE132L-DHMDKK, ZZE132L-DHMNKA, ZZE132L-DHMNKK, ZZE132L-DHPDKA, ZZE132L-DHPDKK, ZZE132L-DHPNKA, ZZE132L-DHPNKK, ZZE133L-DHFSFA, ZZE133L-DHFSFK, ZZE133L-DHPSFA, ZZE133L-DHPSFK
2003-2005 Toyota Matrix CE, LE, S, STD, XR, XRS|4 Cyl 1.8L 1ZZFE, 2ZZGE; 1ZZFE, 2ZZGE;
For ~$25, might be worth taking a chance on one
I think you need something to slide in the connectors to get them to release, google up fuel line disconnect tool. I once made one out of the plastic tip from an unused tube of caulk, but wish I had bought a real tool instead
drfrisker
Re: Fuel line leak
Post by drfrisker »
ZZvroom wrote: ↑Mon May 30, 2022 9:27 am 2003 GT
Did the line fix it? Mine just sprang a leak too.
ZZvroom
Re: Fuel line leak
Post by ZZvroom »
To be honest, I've not replaced the line. The kludgy fix is still dry..
I think it will require dropping the tank.
ZZvroom
Re: Fuel line leak
Post by ZZvroom »
We lowered the tank enough to swap the new line in,
As I've mention in another thread, it seems a rat or squirrel chewed at it.
