New member - need help finding front axle seal
shjackson83
Post by shjackson83 »
New member here. Hope I'm doing this right, since I posted this very same 'new topic' a week or so ago, but cannot find it when I search on 'my posts'. Hopefully, second time is a charm. I have a 5-speed manual 2010 Vibe GT that has beginnings of a front axle seal leak. My problem is I cannot, nor can my mechanic, find a replacement seal, since it is 'discontinued' by GM. Here is part # GM 19205379 Seal,Front Wheel Drive Shaft. I've done a bunch of google searches in vain. Hopefully someone on this forum has an idea how I can find the seal. Many thanks.
SSizler
Re: New member - need help finding front axle seal
Post by SSizler »
Welcome to the site.
Try searching for the same seal on a 2010 Toyota Matrix.
I think XRS is the comparable model to the GT.
You should be able to find one fairly easily.
Good Luck!
06 AWD/Abyss Black Mono/Loaded/Spoilers/Ground effects/172k/ 2025 Vibestock "Most Bling" Award
06 AWD/Lava Red Mono/Loaded/Spoilers/Ground effects/Leather/150k
05 Base/ Lava Red/ Daughters Car
06 Base/Gray/Totaled 5-24
03 Base/White/Totaled 1-23
shjackson83
Thanks for lead. I'll track down a seal.
