finding replacent Right Front CV axle
muttleytm
Post by muttleytm »
I've bought two axles from two different places and neither fit. I have a 2003, base, automatic without ABS. Here is the old one that was in the car Image. There are some stickers on it that have the number TF2172A0237 printed on it, here is a picture of that: Image
Just using a tape measure the original axle was ~36" long. The two ones I bought were shorter.
The one I removed had the sort of bulge between the CV joint's. Don't know if it is necessary or what it is for. Looks like a damper.
I've read the early 2003s had some different sized shafts and transmissions as well.
Anyone know about this and the situation today getting replacement parts?
Re: finding replacent Right Front CV axle
according to this excerpt from the 03 Matrix parts pdf
seems like the toyota part number is 43410-02320 but I don't know if toyota still stocks them
muttleytm
Post by muttleytm »
All I see is it is an obsolete number and I don't see any replacement numbers given or cross references, etc.
Same with the GM PN
I use this Toyota parts site: http://www.japan-parts.eu/toyota/us/200 ... ft/1#43410 and it agrees with the above.
SeattleJeremy
Post by SeattleJeremy »
Note: Cars without ABS can use the ABS shafts.
The ABS shafts have a toothed ring, non-ABS shafts have a smooth metal ring in that spot.
Want to sell:15' BMW 328i Sport - Jet Black - Auto
Daily 19' Toyota Camry SE Hybrid - Galactic Aqua Mica - eCVT
if you can't find a new one maybe look for one in a junkyard
car-part.com is a good junkyard search tool, looks like a lot of them listed, maybe you can find a yard with one near wherever you are
