On the plug the green wire with red bands is the positive power going to the dome light. You can separate it from the connector and dome light a bit, then de-pin it from the connector. I’m not going to cover the depinning here much, but be aware that this connector has a lock that needs to be pried up before you can de-pin the wire.
The red wire with silver bands is the keyed positive power. To keep this reversible I chose to simply insert the pin on green wire right under the red wire in the connector. Stuff it in there until it’s snug, then zip tie the green wire in along with the other wires in the cable bundle going to the plug. That way it can’t back out. Done!
