grrlinsuperior wrote: ↑Fri Apr 29, 2022 3:00 pm
i need and cant find what all the 6 pins on the harness or igntion switch relate to
Here is a portion of the second page of the power source PDF that shows the wiring for the ignition switch
- igsww.jpg (20.22 KiB) Viewed 4499 times
The white wire connected to pin 1 gets 12V from the AM1 fuse
The black wire connected to pin 5 gets 12V from the AM2 fuse
The Blue wire with red stripe connected to pin 3 provides power to the ACC circuit
The Black wire with yellow stripe connected to pin 2 is connected to the coil of the Ignition Relay, which causes it to close and provide power from the`100A ALT fuse to provide power to various circuits when the car is running
The Black wire with white stripe connected to pin 6 provides 12V to the ignition coils
The Red wire connected to pin 4 provides power to the logic that controls the starter relay (The starter gets high current power directly from the battery, the starter circuitry just powers the starter solenoid.) see the starter PDF to see where that goes
When the ignition switch is in the off position, both the inputs from the AM1 and AM2 fuses are connected to nothing.
When the switch is in the ACC position, power from AM1 pin 1 is connected to the ACC line (Blue/Red pin 3)
When the switch is in the run position, power from AM1 pin 1f is connected to both the ACC line (pin 3) and also the IG1 line (Black/Yellow pin 2
and also power from AM2 pin 5 is connected to the IG2 line (Black/white pin 6)
When the switch is in the Start position, AM1 pin 1 is disconnected from ACC pin 3, but still connected to IG1 pin 2,
and AM2 pin 5 is connected to both IG2 pin 6 and ST2 pin 4
