First time posting here.
2009 base Vibe, 1.8 L, FWD, manual transmission, ~130k miles, purchased at ~80k miles.
Recurring issues:
-Ignition coils, replacing them one at a time much earlier than expected miles
- Rough start. It always turned over, but might crank for 5 seconds. Previous mechanic suggested it was a fuel pump that lost its seal, requiring longer for the fuel to get from the tank to the engine
-A semi-regular rough idle
Two months ago, on an incline at 75mph on cruise control, the RPMs suddenly raised dramatically (odometer and engine noise), while the car's speed slowed. I took it off cc, and as long as I didn't accelerate on inclines and kept the pedal at a certain point, the car could maintain speed. The problem got worse over time. I assumed the fuel pump had finally given out, so I had it replaced. The car ran very smooth for a month. The problem slowly returned, but then got worse where acceleration would be very slow and mechanical power weakened on flat surfaces as well. A light chunk or shearing sound also began irregularly from the engine. I guessed that sound was a piston turning over without fuel, that the fuel wasn't getting to the engine? Two months after the initial incident, and a short road trip of the same symptoms, the car barely rolled to my AirBnB and now no longer moves. The engine starts fine, all gears appear to engage, the clutch feels good, no lights or codes, but no movement.
My assumption is that the motor in the new fuel pump was shorted again by an underlying electrical/ grounding issue (the ignition coils?), which then starved the engine of enough fuel that the transmission just went. I'm not a mechanic and that is a very uneducated guess. The car is currently with a shop and I'm not confident of what they'll tell me.
Any ideas?
Updated: after reading more about transmission symptoms, I never had any issues shifting gears at the shifter, there were no other noises, but the dramatic increase in RPMs while losing power suggests the gear slipped out near the engine?
