Inverter question
Bookworm
Inverter question
Post by Bookworm »
I haven't pulled seats loose to check - does anyone have any experience with installing the OEM inverter assembly (switch, inverter, etc) into a Vibe/Matrix that didn't come with one?
Mostly, I'm trying to figure out if the relay for the 110 is already inside the 'new' car, or if I'll be robbing that from the old vehicle as well.
I haven't used the 110 in a couple of years, but I like having the option.
Re: Inverter question
in 03-08's, the inverter relay is in the small relay block above the glove compartment
you should be able to reach up on top of that relay block without taking it loose and feeling for the relay to see if its there.
Bookworm
Post by Bookworm »
I'll try to do that tomorrow. (car's 15 miles away, roughly, at my folks).
So all the wiring should be in place for the inverter under the seat? That'll be nice :)
Bookworm wrote: ↑Tue Mar 08, 2022 2:09 pm
when you find out, you'll be the first to know, so let us know when you do
cigvibe
Post by cigvibe »
subscribed for future matrix use :)
Cali Vibe 238k Wave Blue
mods
2zz "brown" 320cc injectors - Full time E85 gas - K&N airbox insert - charcoal filter delete - 3" fresh air duct
Bookworm
Post by Bookworm »
I haven't pulled the seat out to check the plugs, but I did dig around under the dash. The relay is definitely _not_ included in the base model. So I'll have to rob that along with the inverter and dash assembly.
I was MIA for a while after switching jobs and forgetting my password to here lol...Finally had Mike manually reset me.
Anyways, I don't think the wiring is there for the 110 stuff. I only say this as Vibes that did not come with power windows/locks do not have the wiring present. I also know that my 2004 GT did not come with the sub in the back for the moons and tunes...Sadly, if it didn't come with that sub, the wiring doesn't exist to add the OEM one.
Bookworm
Post by Bookworm »
Interesting thing.
This is a 'Base' Matrix. Apparently in 07, Base meant
Power locks
power windows
cruise control
12 volt in the console box
I've already put in power mirrors - the wiring was in place.
it doesn't have fog lights, and it also,oddly enough, doesn't have the intermittent wiper control ring. it' has OFF, INT, I, and II.
I didn't get to pulling the lower dash open to check for wiring, nor have I dug under the seats, I've been focused on that P0171 problem. After reading through ToyotaNation, I'm starting to think maybe it is the injectors.
Bookworm wrote: ↑Mon Mar 21, 2022 8:47 am
Fogs are probably plug-n-play with the addition of the relay and the turn signal switch...Same with intermittent wipers.
Good luck on your mysterious P0171.
Bookworm
Post by Bookworm »
Okay - I crawled under the driver's seat on both the fully loaded M&T 07 Vibe and the base 07 Matrix.
The wiring harness specific to the inverter is -not- present on the Matrix. So, for me, it means it'll be simpler to just carry a small 100 watt inverter around.
