What is the correct OEM MAF sensor?
butlerjonas
Post by butlerjonas »
2009 Vibe GT, 2az fe engine. I've bought two Denso MAF sensors and they both crapped out in a matter of months. Cleaning them did no good, but replacing them worked for a while. The one in my car when I bought it was a Denso, but I've heard I should get an AC Delco or Delphi. I'm not made of MAF sensors, ya know! Please advise.
09 Vibe GT
2AZ-FE 2.4L (upgraded pistons)
Valvoline MaxLife Full Synthetic 5w-20/Toyota TRD filter
Valvoline MaxLife ATF
Toyota/Denso air filter
NGK Laser Iridium spark plugs
Broken volume knob
Vibration at idle
Re: What is the correct OEM MAF sensor?
Pretty sure Denso is the OEM MAF, given that this is a Toyota.
Cleaning MAFs is pointless for the 2 microscopic specs of dust they may accumulate.
If you are buying MAFs from eBay/Amazon, odds are you're not buying real ones.
What says the MAF has died repeatedly? What is the CEL you are getting?
butlerjonas
zbyers wrote: Thu Sep 30, 2021 4:16 am Pretty sure Denso is the OEM MAF, given that this is a Toyota.
Bought the MAF from Advance Auto. Denso #197-6110. Code is P0101. No other codes and obd shows airflow and fuel trims going haywire, like 25 grams per second at 1500 rpm, and negative 20+ LTFT. I also read reviews that this MAF didn't last long for other people either.
I think you're right, though. Most "AC Delco" parts for this car are really Denso or Toyota.
I also don't think I was clear before. I've only bought this one MAF that failed in 5 months. The original one failed after 12 years.
09 Vibe GT
Broken volume knob
Vibration at idle
butlerjonas
*update*
I Cleaned the MAF with CRC cleaner. I Didn't think it would help, but the wire that faces the airflow was a tad darker/duller than the others.
Anyway, now at idle:
STFT: -0.8
LTFT: 0.0
Success!
09 Vibe GT
Broken volume knob
Vibration at idle
cptnsolo77
Post by cptnsolo77 »
I was able to purchase a Denso MAF through amazon for 100 bux.
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
