How to remove plastic pillar cover, Passenger side
coppens1
Post by coppens1 »
Dear fellow Vibe owners, I need to remove the plastic pillar cover, on the front Passenger side of my 05 Vibe, to look at a leak there. How do I do it? Does it just pop off? Do I use a screw driver? Please provide details, including a photo, if possible. JC
jolt
Re: How to remove plastic pillar cover, Passenger side
Post by jolt »
Here is link for removing the head liner. It shows how to remove all the pillar covers.
https://www.madstyle1972.com/Repair/76/ ... 040001.pdf
dougreed
Post by dougreed »
Yes, it just pops of. It may be tight, but it is held in with plastic "christmas tree" type push pins. I just pull the rubber door seal loose and start wiggling the panel as I pull and it pops right off. If there is a leak you really should seal it on the outside of the car.
