-Replaced all engine/trans mounts twice and I will explain why: Early 2020 I replaced the front and side mounts myself. The rear mount ( firewall side ) looked to be too much to handle so I decided to have a mechanic take care of that one. COVID came in and I did not feel comfortale taking it to a shop...so for 9 months the car vibrated terribly and violenty. I found a mechanic that would come to my house so it will be safe repair pandemic wise. He replaced the rear mount and it was shot, completely torn. Practically driving with 3 mounts. After having that last mount replaced, I still had this vibration at idle. Being that I drove with a mix of new/old mounts....I suspected after 10,000 miles maybe I prematurely worn the new ones. So I did a little experiment: I replaced one mount at a time and see if the issue improved...and it did. As I replaced each mount, the vibration became less and less. So its looking good here right ? When I had the rear mount left and still just a bit of vibration, I thought that this last mount would finally do the trick. It did not change anything. So I guess I can rule out engine/trans mounts now LOL. The mounts are all Toyota OEM.
-I do have a PO 442. Replaced both gas caps, purge and vent evap solenoids had a mechanic do a smoke test. He couldnt find any leaks, he suspects the charcoal canister maybe leaking internally. In my opinion if the leak is that small, it wouldnt contribute to THAT rough an idle. I could be wrong though.
-Replaced all plugs in the last month, the coils are Denso units that are 2 years old from a missfire I had, so replaced all 4.
-Fan assembly. The other day I noticed when I had the key on/ignition off there was a vibration in the steering wheel. Weird because the engine isnt running. The fan was on high ( car was just driven and I was ready to start it again ) I did this a 2 more times and noticed the same issue. The fan seem to have excessive vibration on high speed. When the car was off I turned the fan blade by hand and just before it stopped i heard a small squeal. My logic...the bearings are worn, and putting a electrical load and causing a little vibration. New fan assembly and no change. I also noticed the vibration was more apparent when the AC condenser fan kicked in on high and that also led me to beleive the fan assembly may be causing my issue. That leads me to the next thing....IAC valve. Im also experiencing a hard start when the car has been sitting after it has been driven. It starts up fine in the morning.
-The IAC and throttle body was cleaned 3 years ago. Aprox. 25K miles ago. This was the 2nd time it has been cleaned. I cant see it being that dirty that it would cause rough idle. Even at the dirtiest it never idled this way. Unless the IAC is just faulty. I do have 272,000 miles now. With the AC on it does idle about 800 RPMS and the idle doesnt dip with a load from the AC. So its seems the IAC is working correctly. I understand that the IAC is supposed to bump up the RPMs when the AC condenser fan kicks in, but my RPMs are steady at 800 and not fluctuating. Again....I can be wrong, thats why I havent fixed it LOL.
Any ideas ? Im stumped. Im starting to think I did some kind of damage driving with a bad motor mount for so long.
****UPDATE 9-9-2021****
CEL gave me a PO303 ( misfire cylinder #3 ) and PO420 ( Catalyst System Efficiency Below Threshold (Bank 1) It would also stumble a little into 2nd and 3rd under hard throttle. I had a spare coil and swapped it out, cleared the code and its been 2 weeks and the 303 and 420 code have not returned. When I replaced the coil I did a little under hood inspection and found the center bolt for the front engine mount completely loose. I tightened it up and went for a drive. Car drives MUCH better, throttle response is improved and the car doesnt feel like its struggling anymore, and not stumbling into 2nd and 3rd. Shifts are very crisp. It still idles a little rough when cold and when the AC condenser fan is on HI, but its improved.
SOOOOO.....Last week I bought a can of Cataclean ( yeah I know
At this point I feel like taking shots in the dark, so I decided to pickup a new MAF sensor. To my surprise, it did smooth out the idle ( old one was cleaned to rule that out ) I even swapped the old one out twice to compare between new and old. New MAF it seems to run better. Have no clue why....
The only time where I feel it idles rough is when the engine is below operating temp OR when the AC condenser fan kicks in on HI. When the fan is on LOW speed I really cant tell the difference now. It used to idle rough in HI and LOW speed.
So after 1 coil, loose engine mount, new MAF sensor and a bottle of Cataclean the Vibe is idles WAY better. Even when I lightly feather the throttle around 50 MPH it feels very smooth. I still have a bit of vibration at idle when the AC fan is on HIGH but its tolerable now. Im begining to wonder if I have another coil that hasnt thrown a code yet, that may be starting to go. I might replace the coils one at a time and see what happens. Driving today I noticed a little stumble when I give it a light throttle coming off a traffic light around 1200 RPMs. Sign of another bad coil ? Either way I feel like Im VERY close to solving my idle issue.....WHEW ! It has been a LONG journey !
*****UPDATE 10-29-22****
Turns out I have low compression likely due to gummed up oil control rings, so I gave a it a shot with BG EPR, valvoline max life and marvel mystery oil. Heres my story:
1st treatment of BG EPR and MOA oil additive in Feb:
-smoother idle. Its proven because my door panel rattle has gone away. Also doesnt vibrate as much when the AC fan kicks in on high.
-smoother throttle response at 40 -50 MPH. On light throttle the pedal feels light and less resistance.
-Shifts are smoother.
-Increased MPGs. Normally I get 75 miles ( at best ) at the 1/4 tank mark after a fill up. Now 93-94 at the 1/4 tank ( after fillup ) for 2 weeks in a row. I can SOMETIMES get that number without the AC running. 93-94 miles has been with the AC ON. These numbers have been consutent for a month.
-Gained power. Car doesnt feel as sluggish as before. Almost like it breathing better.
-Oil consumption: SAME. Still burns 1 QT per 1000 miles. It sure drives better though. That alone is worth it.
2nd Treatment of BG EPR and MOA oil additive, 300 miles later:
- smoother idle from the 1st treatment
- smoother shifts from 1st treatment
- engine feels like it picked up a bit more power
- smoother throttle response at 40 -50 MPH from the 1st treatment. On light throttle the pedal feels light and less resistance a bit more than 1st treatment
- definitely worth doing a 2nd treatment
- Quieted down my cold start rattle. I beleive its the VVT rattle on cold starts.
- Oil consumption: SAME. Still burns 1 QT per 1000 miles.
Switched to Valvoline Max Life Synth Blend ( highly recommended on Bob is the Oil guy and IS the gold standard of high mileage oils on this site ) and 1 QT of Marvel Mystery Oil in May. I was using Super Tech High Mileage synth Blend
- Immediately felt smoother after the oil change
- Idle has gradually become smoother as the months went by. I had a rattle that was behind the dash that only went away after the car warmed up. Doesnt rattle anymore even when cold.
- Increase in power, but not 100 percent
- Oil changes were done 2000 -3000 miles apart and have done 2 oil changes with valvoline oil and marvel mystery oil.
- Oil consumption: Now I am burning 1 QT every 1400 miles and of October compared to 1 QT every 1000. Im shocked, didnt expect any changes. This was my last resort to breathe some life back into the engine. Between BG EPR, Valvoline Max Life, Marvel Mystery Oil, Short oil change intervals I have decreased my oil consumption. Most likely I loosened up sludge buildup around the oil control piston rings.
