Winter Wheels and Tires
JerryV
Post by JerryV »
My 2009 GT has the 18 inch aluminum rims with low profile tires. I am thinking that they will not be very good for winter driving here in MN. Apparently the GT has a different bolt pattern from the base model. A little searching on the site and I found that someone recommended 16 inch wheels from a Camry would fit, but they didn't say what year Camry. Does anyone have some recommendations on what will fit? I'm hoping I can pick some up on Craigslist reasonably. Then I can get some good winter tires and swap them out spring and fall.
Thanks
Jerry
Re: Winter Wheels and Tires
Your bolt pattern is 5x114.3 on the 2009-2019 GT/AWD & Base w/2.4L motor.
Same years Camry or Corolla with the 2.4L engine should fit easily
