I have gotten a cheap one off of ebay. It has a nut at each end to tighten it up. do i install in and then take all the slack out and make it tight? Also the bolts that hold the round thing at the end habe bolts holding them to the cross piece, should i tighten them as well? What do i have to tak off the top of the towers to install this piece?Thanks In advance
quote:I have gotten a cheap one off of ebay. It has a nut at each end to tighten it up. do i install in and then take all the slack out and make it tight? Also the bolts that hold the round thing at the end habe bolts holding them to the cross piece, should i tighten them as well? What do i have to tak off the top of the towers to install this piece?Thanks In advanceremove the 3 nuts on each strut tower. remove the metal ring. put the strut stabilizer bar on and tighten the nuts to 29 ft lbs. then take the slack out of the bat by tighten in the nut on the bar. hope this helps.i got the same kind of ebay. and I'm happy with it
quote:Which one did you guys buy? Is it worth the $?If I'm not mistaken... the one on Ebay is usually the F1 Motorsports STB. It costs usually between 30-45 bucks (remember, it is Ebay, prices change easily). It works great, I've had mine for a long time now, and I love it. The car feels much tighter in the turns
