ab2cmiller wrote: ↑Mon Apr 14, 2014 12:11 pm
Just did the install on my 2010 base Vibe.  Very simple.  Below is the parts list from when I ordered the parts from gmpartscenter.net where the parts cost me about $89 delivered.
The Steering Wheel Plug (Trim Piece with pre-cut hole for Cruise stalk) I think can be bought from Toyota for probably about half that price.
Part Number          Part Name 	              Price      Quantity    Total
19184547 	         F-(S)SWITCH 	            $45.29    	1 	$45.29
19184548      	Air Bag Wiring Harness   $14.90  	1 	$14.90
19204916 	       Steering Wheel Plug        $14.65  	1 	$14.65
19184557   	F-(S)BOLT                      $2.49    	2 	$4.98
Okay so i just did this on my 09 manual. works perfectly.
On the 1st gen vibes, you ALSO need to get the clutch pedal release switch. on the 2nd gen vibes (09-10), the switch is already installed from the factory at the top of the clutch pedal. i believe its the reason you cant start the car without th clutch on the floor. anyway i installed the cruise with only the above parts list on an 09 manual and everything works perfectly.
