03 Vibe w/ 05 Matrix Engine - Hissing Sound below Intake Manifold ?
h0ckeyplayer
Post by h0ckeyplayer »
Got a 2003 Vibe. We replaced the engine with an 05 Matrix engine 2 weeks ago. Runs and sounds like the engine is strong but has a misfire on all cyl. Runs pretty good except idle is kinda rough and after a drive it idles at 2k. I hear a hissing sound when engine is running, not a real loud hiss but it sounds like its coming from under the intake manifold. We changed intake manifold gasket and throttle body gaskets.
What could i do to help figure out the leak? Is a smoke test safe and if so are there any cheap ways to do them?
Thanks in advance!!
h0ckeyplayer
Re: 03 Vibe w/ 05 Matrix Engine - Hissing Sound below Intake Manifold ?
https://www.reddit.com/r/MechanicAdvice ... on_colder/
this is also another issue ive experienced at start up when cold. Its like 2 click sounds after starting. Only happened when its become colder out.
What are the codes the vehicle is throwing?
h0ckeyplayer
Misfire on 1, 2, 3, 4 at work right now so i am not sure the exact codes. Pretty sure it said lean though
I know another one is the exhaust catalyst believe its P0420 (that the sensor for catalytic converter) don't think that one has to do with the mis though.
h0ckeyplayer
pretty sure its P0301 P0302 P0303 P0304
its either those or a P0171
h0ckeyplayer wrote: Thu Oct 10, 2019 7:13 am pretty sure its P0301 P0302 P0303 P0304
First four codes are misfires. I'd check the plugs and coils.
Last code generally is an intake manifold leak/vacuum leak. I would double check the vacuum lines.
h0ckeyplayer
thanks! i will try to check hoses. My neighbor helped me do the engine replacement. I'm just wondering if one of the hoses is hooked up wrong. I know he found one that he put on wrong right after finishing the job with me. I noticed it leaking when first adding coolant. the one line behind the intake manifold wasnt hooked up right. everything looks right but i just got a feeling it could be something like that.
Wish i could find a easy to ready diagram of all the hoses placements.
Where are you located? Perhaps you are near a member on here or on the Facebook group who'd be willing to swing by and give you a hand.
1Vibefrom2
Post by 1Vibefrom2 »
Did you figure this out?
I'm doing a similar swap right now, 06 vibe engine into an 04 vibe.
Read this tip on ToyotaNation, maybe part of your problem?
https://www.toyotanation.com/threads/ha ... w.1108946/
2005-2008 Corolla/Matrix/Pontiac Vibe engine in a 2003-2004 Corolla/Matrix/Pontiac Vibe:
Almost direct swap - If the engine has an intake manifold it will need to be swapped with the original manifold from the 2003-2004 engine. Also the sensor in the exhaust manifold is not the same and will need to be swapped from the 2003-2004 if it is used. The wiring harness is also different and the original will also need to be swapped if the engine came with one.
